Question about Panasonic TH-42PZ77U TV
Panasonic won't display picture is blinking 10 times
5 Suggested Answers
SOURCE: Power light blinks 10 times
You have the same problem i have. My Tv just did the same thing 3 nights ago. I unplugged the set, and let it sit ofr about 6 hours, and then tried it again. It turned on and played, but repeated the problem after about 20 or 30 minutes. So far all my research has led me to believe that its a power supply issue. Problem is, there are 5 boards in the tv with seperate pwer supplies, and the 10 red flashes indicate that its all of them. :-(. Im shopping for a new TV, and It wont be a panasonic this time.
Posted on Mar 08, 2008
Anonymous
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
phil_frye
Philip Frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
Sean
  • 80 Answers
SOURCE: Panasonic t.v. Power light blinks 10 times no
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
found this online hope it helps...
42"plasma purchased nov-07.I was watching t.v and it just shut off and nothing no blinking light nothing so changed the fuses in the back and went to turn the power back on and all i get now is 10 blinks then nothing.I have the t.v at the service man and he is telling me its the power board and after the price of the board and his labor charge it will be around $300.
G.L. scroll down for image
Posted on Apr 24, 2011
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: I have a Panasonic model
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Posted on Jul 18, 2011
2010 Panasonic tc -p54s2. 10 red blinking light on power up. No picture.
10 binks? Might not be. Just count once more. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 04, 2016 | Panasonic Televison & Video
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
No picture or sound, red light blinks 10 times
Usually, 10 blinks to LCD TVs denotes a sound processor fault.If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 09, 2013 | Panasonic Televison & Video
Blinks 10 times
Yes, it is going to be most likely the power board or something connected to it----voltages will need to be checked---most authorized Panasonic shops will also know what is bad in advance.
Oct 30, 2012 | Panasonic TCL32C22 32 in. TV
I can't get my panasonic 58pz800u on the red light blinks 10 times
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 880 posts to different brand TVs now.
Count the number of blinks occur at one time very carefully. There is no chance for a 10 blink pattern for this TV.
Oct 01, 2012 | Panasonic TH-58PZ800U 58 in. HD-Ready...
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic tcp42s1 red light blinks 10 times and no picture
Normally 10 blinks means the main board is having an issue.. if you get 7 blinks than a power supply problem.
Aug 26, 2010 | Panasonic Televison & Video
TH-42PX80U
i have the same problem but i have 11 blinks
Aug 13, 2008 | Panasonic TH-42PX60U Television
Panasonic TH-42PZ77U TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
