Ovwrheating is sort of common after extended use on almost all smaet phones. Now if it gets hot enough to the point it will litwrally make somthing sizzle when u place your phone on it thats a problem. The battery must have short circuited or somthing. If you use for hours on end with no break its notjing to worry about just let it rest with battery out of it for 30 mins will be fine again. If its lime that no matter what claim the warranty on it before your house burns down....
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
heatman101
Asker
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
