When dongle is in HDMI port (HDMI 2-4) all's well but can't get back to TV (HDMI 1 in my list) after using Chromecast. Tried a lot of things but no go. TV functions well otherwise.
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
SOURCE: hooking up pc through hdmi - red flickering image
The format from the PC needs to be an HDTV format: 480i, 480p, 720p, 1080i or 1080p. Other formats will generally not work. You may need to get the latest drivers from your video card manufactures website to correct the problem. I hope this was helpful, best wishes.
SOURCE: Sony KDL-52V5100, HDMI 1 shows
I had this tv for almost a year, and I experienced this exact same problem about 3 or 4 times. The only thing you can do is turn the tv off and unplug it for a couple minutes. When you plug it back in it will work. This issue along with the intermittent sound issue on HDMI fed sources drove me crazy until I exchanged my tv for a KDL-52EX700. So glad to be done dealing with Sony customer support...because they're TERRIBLE. I had to email a VP at sony to get any results. The picture is beautiful on the V5100 for a lcd, but it's not worth dealing with the other issues...it's a flawed model. Hopefully your tv is still under warranty...you will have to call Sony and tell them your problem. They'll send a tech to come out, and he'll probably change out the motherboard..it won't fix anything. Then they'll probably send a tech out again to do the same thing when you keep calling...eventually they'll offer you an exchange. That's how it went for me...it was a 7 month nightmare.
