Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Ricoh m161 how mash price
Ricoh 3045 toner
Name : RICOH TONER BLACK TYPE 3110D
Toner Yeld :30,000 pages at 6%
Weight : 550 grams
Price : Around 60 euros
Oct 03, 2013 | Ricoh Office Equipment & Supplies
Problem installing AR-M161 windows 8 64 bit
Thank you man but these keys didn't work for me. Guys you can go to https://plus.google.com/103156713044838092165/posts/WBduJyEaG5v to get genuine win 8 keys in a cheap price, I got one there several days ago, it's not bad.
Nov 02, 2012 | Sharp AR-M205 Copier
Price of print cartridge
Depending on the vendor, you can get the Ricoh 406464 toner for the Aficio SP 3410SF (regular cartridge, not the high yield one) for between $65 and $90 . Some sites to look at http://www.bluedogink.com/ricoh-406464.html and http://www.staples.com/Ricoh-406464-Black-Toner-Cartridge/product_332848 .
I hope this helps.
Sep 15, 2011 | Ricoh Aficio SP 3410SF Laser Multifunction...
We have a Ricoh copier Aficio 1022 and the info
The Photoconductor Unit or PCU is easy to replace. The box will come with instructions but it is basically a slide in unit. They will vary in price depending on where you go. You might find one on Ebay cheaper but they generally run around $225. Keep in mind this is a drum/developer unit combination so you are replacing pretty much everything that controls copy quality.
Ricoh part number is 411018 or a type 1027 photoconductor if that helps your search.
A good source for you on parts, toner and supplies is precisionroller.com
They have everything you would need at very competetive prices with free shipping.
Not affiliated with them in any way, just use them regularly.
Good Luck
Jan 05, 2010 | Ricoh Photoconductor CLRType 145 Printer
Sharp AR - M161 Copier Driver for Vista
There is a vista driver available for that model as long as you are talking about the M161 not 161. Do you have the optional print kit installed or only parallel interface. If you only have the parallel connection it requires the GDI driver which can be downloaded from Sharpusa.com under support then type your model and select OS and driver type GDI
Hope this helps,
TankMurdock
Mar 17, 2009 | Sharp AR-M205 Copier
Just want to know the real price
Hi Ms Belle, this is an older model fax and you can probably pick one up second hand for around $100-$200 dollars
May 07, 2008 | Ricoh FAX2900L Plain Paper Laser
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
53 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
