When you start your machine is the water just go stop go stop, Just wait for the machine to display an error code on the wash progress lights and beeps constantly. It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch. Your error code will determine this. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on.
Red spin light = 1
2nd rinse light =2
1st rinse light =4
last wash light=8
4th wash light=16
3rd wash light=32
2nd wash light=64
1st wash light=128
The Beeps you are referring to are 'POST' beeps ( Power On Self Test ). In this case one long and one short is indicating a Board Problem. Depending on the Age and Spec of your machine this will be borderline to repair or replace. If you had further specs i'd be happy to advise
Probably the key board is bad you can try my tip under WW 1000 or contact Geo. Beters Co. @ 800-392-8085 for a key board rebuild. Tell them O'Reilly sent you.
The keyboard is going bad. You can try my tip under WW1000 or have it rebuilt, contact Geo. Beters Co. @800-392-8085 for a rebuild, tell them O'Reilly sent you.
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone.
Good luck.
Thanks for using FixYa.
It should at least beep. Those beeps are diagnostic codes. Listen to the beeps and google 'bios error beep codes'. If it doesn't beep, the motherboard must be replaced.
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
