Question about Olympus Stylus 850SW Digital Camera
Monitor shows autofocus and other icons, but rest of screen is black when power is turned on
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computers & Internet
Desktop screen
try booting in safe mode and see if the screen displays properly.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the 1 inch black space then your video card might be going bad or you might have a virus infection. If the Borrowed monitor displays ok then your original monitor is bad.
May 29, 2012 | Dell Inspiron 530 Desktop Computer...
Coby nnbpc1023 netbook screen is black power is on
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 13, 2012 | Coby NBPC1023XPBLK Netbook PC
My Acer Aspire 5551-2036 wont turn on blue light turns on screen remains black
Does it sound like the laptop booted up except the screen is black? Do you hear the fan running and the hard drive spinning? If so try the steps below.
May 06, 2012 | Computers & Internet
I have a CQ60-615DX and when I turn it on the screem is black, so what is the problem.
When you turned it on does it seem like the laptop booted up all the way except the screen is black? Do you hear the fan running, the hard drive spinning and everything seems to be ok except the screen is black?
Apr 23, 2012 | Compaq Computers & Internet
Monitor will not turn on
Monitor will not turn on as in NO Power? When you hit the Power Button the monitor power light does not come on? If so either the power cord is not plugged in good, maybe the outlet you have it plugged into the wall or power strip is not working, or the Monitor is bad and needs to be replaced.
If you are saying the monitor has power but the display is black then:
Look to see if it sounds like the computer is running but nothing is shown on the screen. If so try this:
Apr 06, 2012 | Toshiba Satellite P35-S611 Notebook
Why does Sony laptop screen stays black when booting?
Mar 31, 2012 | Computers & Internet
My monitor is on. it is a samgung monitor. all i
turn off the CPU then open and find the memory slot, just slowly attached the memory and put it back tightly. and then try to open the computer again...
Nov 26, 2009 | Computers & Internet
Monitor goes black but shows icons...
I'll assume this is an LCD panel screen.
If what you are saying is the screen shows up and then goes dim or starts dim, and you can see a dark image of the system starting up and then displaying Windows...
Your problem is a bad CCFL (Cold Cathode Fluorescent Lamp) at the top of the LCD panel.
If the screen is totally blank, then it may be the power inverter.
You can find many websites that sell these parts, but make sure you have the right model.
If you feel comfortable with working on computers, you can replace this part yourself. Otherwise, you may want to pay a technician to do it. Make sure to get a fixed price quote before authorizing the work
Here is a website on LCD repair for laptops, but it the same principal for display monitors.
http://www.ccfldirect.com/lcdtutorial.html
RDO
Nov 16, 2008 | HP vs15 15"LCD Flat Panel Monitor
Olympus Stylus 850SW Digital Camera Logo
52 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
