Question about Maytag Neptune Washer
How many cubic feet in the neptune model MAH 6500 AWW?
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Maytag neptune washer mah 6500
why is my washer leaving brown black lines on my clothes
Posted on Sep 08, 2009
caroldon
  • 17130 Answers
SOURCE: My Maytag Neptune MAH4000AWW sounds like a train during the spin cycle. Are the bearings replacable
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jun 12, 2012
I have a Maytag Neptune MAH 6700 AWW. It is shutting off and giving error code tE. Customer service does not recognize the error code. Can you help?
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Jan 23, 2012 | Maytag Neptune MAH5500B Front Load Washer
IHAVE MAYTAG NEPTUNE WASHER MODEL # MAH4000AWQ.I WANT TO KNOW WHAT IS THE SIZE IN CUBIC FEET?
If my calculations are right, this washing machine is approximately 3.00 cubic feet. You may want to double check it for yourself, though. I used http://www.ehow.com/how_6358141_calculate-cubic-feet-washer.html (updated 5/7/2010) to help in the calculation. My machine was approx 15"/1.25' deep and 21"/1.75' high. Hope this helps.
Aug 18, 2010 | Washing Machines
What is the cubic size of my maytag neptune MAH 1 washer
You can find the literature at this Maytag website if you have the correct model number.
Have a great day.
http://www.maytag.com/support/manuals_literature.jsp
Jul 05, 2009 | Maytag Neptune Washer
Mah 6500 spins but leaves som water in tub. if you
they have a balance ring on the front of the tub and it's full of water
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
What is the capacity of the maytag neptune mdg4000aw
motor 1/2 horse power,,,electrical,,120 60 hz,,15 amp breaker needed,,weight 160 lbs,,,capacity 3.2 cubic feet..about 26 pounds...onthe job
Jan 18, 2009 | Maytag Dryers
My Maytag Neptune 7500 front load washer will not turn on when the AC or heat is running
Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
Jan 02, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
