I would try to turn it off and turn it back on again and reset your tablet to see if it stops freezing if it keeps on continuing to freeze their could be something wrong with the tablet it's self and it will need to be repaired and looked at by a person that repairs tablets. It is possible that it may have a virus then that can happen tablets being hacked or getting a virus in them or spyware or greyware then.
Hello Friend
An HDMI dongle allows you to wirelessly display content from your Fire tablet to your TV or media streaming device.Tap Display & Sounds, and then tap Display Mirroring. Tap the name of your TV or media streaming device. This initial connection may take up to 20 seconds. For any help or support just visit us: www Kindle Com Support
To help you understand and delete the bookmarks from your android tablet, make sure you really want to delete it, and that you've chosen the right bookmark because this would delete the bookmark completely.
Please follow the steps given below:
- Launch your Android web browser.
- Tap the 'Bookmarks' icon in the top right hand corner.
- Tap and 'Hold the bookmark' you want to remove, until a window pops up.
- Select the 'Delete bookmark' option, then tap OK.
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
Get an Android Tablet out of safe mode
Use the following steps to get out of safe mode.
1.Restart your device by holding the power button, then tap Power off.
2.Tap Ok to confirm.
3.Power the device on. Your tablet should now be out of safe mode. If the device is still in safe mode use one of the following methods.
·Uninstall the last application you installed:
1.From the Apps menu, tap on Settings.
2.Tap on the app and then tap on uninstall.
3.Restart your device.
·Perform a factory data reset:
1.From the Apps menu, tap on settings, and then tap backup and reset.
2.Tap on factory data reset, and then tap reset tablet
3.Tap erase everything to format your tablet back to factory default configuration.
Unfortunately, your tablet manufacturer maintains a "walled garden" of applications. That is, you can only install applications from a list of applications that they provide. Not all of the Android applications that are available through Google Play are available to this device.
The only way you'll be able to get around this limitation is to hack the tablet (if such a hack is available) to allow installation of either a full Android OS or other hack to allow Google Play. Doing this will void your warranty at least or could "brick" your tablet.
'jailbreaked' = firmware hacked 'illegally'. Factory settings will not be available because the original has been over written. Only possibility is another risky firmware hack, if you know what your doing.
If you go to the Gateway computers support site there may be updated drivers or software for your tablet pc that allows tweaking the mouse pad adjustments (with more refinement possible than was on your tablet originally).
It is also possible that the pad is experiencing wear / mechanical problems.
