If you go into "user tools" is there a printer and scanner option there? If not the MFD does not have the print option.... If it does you need to program the IP address sub net and gateway. -Carl
If you have used various computers with different OS's and you still cannot get any to recognize the printer, then it would appear that the printer electronics are fubar.
U might check with Ricoh but ......................
In general the SC 860-900 refer to HD acces error. SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
format the hard disk if available check wheather there is not any paper in duplex or in the machine if not then check paper settings if not then execute memory clear if not then replace the registration sensor and exit sensor if not then replace thermistors if not then replace nvram
