I believe that HE4T had design problem on control board and had many issues like you later they released new control board. Many users tried to claim as lemon but weren't happen. I replaced control board few years ago and never problem again. cost around $200 I remember. find control board with lifetime warranty with some extra cost..
Http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
if it doesn't work replace the flowmeter.
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
Select the wash cycle and press the "Start" button.
If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
