Question about Hammering
How to lubricate electric demolition hammer
What kind of grease need to be use
  • 2,015 Answers
Only lubricate is not enough,the kind of grease is brand and breaker type dependent , but a consumables kit and a condition that the machine that front that the striking pin in the front air and lubricant is closed in terms of oil seals etc completely closed has very high priority otherwise it is only momentary, because all O-rings, etc. are to fast getting hot again a rapid solidification and its leaking again , and premature all kinds of rings are hardened again, therefore there must be a service (maintenance kit (spare parts) are used A NOTE a rotary hammer is not a demolition hammer and there is often more wrong with and most times too expensive to service in proportion to hidden defects with respect to the new price it than a heavy breaker
Posted on Dec 18, 2015
6ya staff
SOURCE:
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: Need manual for Hitachi Demolition Hammer
http://www.hitachipowertools.com/product/files/concrete_masonry/demolition_hammer/H65_OM.pdf
Posted on May 28, 2009
Robert Sabino
  • 142 Answers
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Posted on Jul 06, 2009
deme-tri
joey temal
  • 90 Answers
SOURCE: grease has been coming out round hole where the
IF ITS A NEW MACHINE DON T WORRY THATS NORMAL
THE MACHINE SHOULD BE SERVICED EVERY 6 MONTHS.
DEPENDS ON USE
Posted on Aug 04, 2009
John Trevino
  • 1420 Answers
SOURCE: I have a demolition hammer
For most climates a good oil to use is air compressor oil (mineral). Sold at Lowes and many other stores. It has great lubrication properties and can take good amount of heat. In very cold climates where oil could thicken, store hammer indoors to keep warm until ready to use. Good luck
Posted on Jul 01, 2011
Graham
  • 304 Answers
SOURCE: Electric kango dem. hammer needs lubricant is it oil or grease Mod. 800
A basic lithium grease should be ok. Get it from the car shop. nothing too heavy.
Posted on Dec 17, 2012
How to put oil in Hitachi H65
OIL ?? I think Hitachi has always a yellow grease lubrication
hitachi grease demolition hammer Google zoeken never seen heart of oil in Hitachi demolitions. but there could be models in your Country thats new for me .
Otherwise BOSCH HILTI and the one and only brand DUSS demolition hammers and also a few brands of Chinese hammers need oil lubrication . an expensive sinc-free hydraulic oil the same as used in some pressure washers life lasting oil but for HItachi look at the link for the grease 2 tubes a enough . good luck and dont forget the piston pin to replace with a new not only the gaskets and o-rings and also the oil and dirt seals on the front where the striking pin is that must be absolutely not air leaking because all your work burns in a few months again out . you can start all-over again.
May 15, 2014 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Type of oil use for demolition hammer
A old black graphite or yellow grease lubrication of the brand Makita
Apr 29, 2014 | Makita Hammering
Bosch demolition hammer wont hammer
MUCH NEWER BOSCH demolitionhammers have a special consumables kit you MUST use anyway its marketing technical made exactly on the calculated operating hours.
Every tools has his own kit and by the heavier models of powertools a very special lubricating oil instead of grease that was used by the older tools that are working with a slower tapping block instead of a very fast battle piece.
Apr 12, 2014 | Bosch Hammering
What is (60 g) of grease
181490-7 grease 30g 1 pcs complete be shure there are no cured o-rings or bad gaskets .
188015-8 its the maintenance kit for the service it contains already this 30 grams grease, where come 60 grams advise ? i like also to use some more grease by this heavy kind of hammers. But tools like Hilti with liquid (oil) lubrication and very tight tolerance ball bearings if there is to much (turmopol) oil used it will be damaged, and too little oil also its calculated. I cannot give garantee that 60 grams are advised by a makita service, if you order a maintenace kit ask the seller about why it only contains 30grams. The information to use 60 grams ? doubt.
Mar 30, 2014 | Makita HM1810 Electric Demolition Hammers
Nov 25, 2012 | Hammering
Bosch demolition hammer lubricant
OR fett (grease) or special oil depends on model.
Nov 01, 2012 | Bosch Hammering
Where do I ad oil to a makita hm1500 demolition hammer
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
Jan 20, 2012 | Makita Hammering
How to fix
193243-2 revision maintenance service kit With all necessary rings and fat , beware before ordering an service kit take the time to remove all parts of the spindle ringing on the hammer tube spindle for cracks the chisel sds impact bold striker must be even air-tight on the chisel impact bold not leaking grease out of it , if its leaking the air flow will burn the o-rings in a very early time because of the building heat made by the leaking airflow . and loose of lubrication. fat grease .
Jan 01, 2018 | Makita HM1100C Electric Demolition Hammers
What type of oil i will luricate to my makita HM demolition breaker
demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
Feb 25, 2010 | Makita Hm1500b 42-pound Demolition...
Hammering Logo
403 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Hammering Expert? Answer questions, earn points and help others
