Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse plasma tv blinking all kinds of colors onf screen what causes this
Tv blinks all kind of colors on screen, then it stops and I can see the picture then it start blinking colors again and this goes on and on allday, until I turn the tv off, is the color tube going out?
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Westinghouse SK32H240S TV will not show picture...
Some solutions to this same problem were posted here, hope this helps.
Posted on Dec 30, 2008
Anonymous
  • 44 Answers
SOURCE: Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
Posted on Mar 04, 2009
Anonymous
  • 150 Answers
SOURCE: Westinghouse 26" tv SK-26H730S HDMI screen blinks with Dell Comp.
try using the 27 pin monitor input instead the hdmi possibly has a frequency variance
Posted on Apr 16, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 28, 2009
Testimonial: "Plug and outlet are ok, well drop it off at best buy to fix. Thank you."
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I am having problems with my Westinghouse LTV-32w3
The LCD controller is bad, after about on for 30 minutes, see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notee: my pix show the board with the cover removed. You can run the TV with the back open and have s small fan blowing in the back to keep it cool.
You need new LCD controller (there are more than one version, you need to match with the LCD panel): http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Posted on Jan 04, 2010
What are the blink codes for an lg 60pa6500 plasma logic control board?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 14, 2016 | LG 60PA6500 60" 1080p Plasma TV - 16:9 -...
Why does my 4year old Panasonic plasma flat screen tv have vertical stripes and will often not turn on but red power light blinks?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
LED blinking codes to Plasma TVs too is given.
Mar 23, 2015 | Panasonic Televison & Video
Why is the 7 red blinks of *****
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Panasonic TCP65VT50 65 in. 3D Smart Plasma...
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Has sound but the screen is black, no red lights of any kind, but there is 2 green lights on the LA2 board and the 1 on the left is blinking
Unfortunately, most of the boards in that set can cause that symptom. You could have a trained TV technician diagnose it. You can also call Tri-State Module and ask their technicians for help. Below is a link to a parts list for that TV model.
http://www.tristatemodule.com/t-Search.aspx?q=42PF7320A
Nov 03, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Westinghouse tv screen wont stop blinking different colors
I just had the same problem with my 50Inch. I tried calling the customer service number and waited three different times. The line just hung up on me as I became the next caller. Absoultely insane. I will never buy a westinghouse again. However, my tv was blinking from black to white to red to green to blue- the entire screen. I tried multiple things. eventually i held the EXIT button on the factory remote. This seemed to exit the safe mode of whatever it was in. I then changed the HDMI plug to the #2 port. Currently it is working normally.
Feb 26, 2013 | Westinghouse Televison & Video
Tv was on then had color spectrum full screen then it went black with space at top of screen 50 in plasma insigna
there are several board in plasma tv which can cause this kind of problem. there is Y board, there is X board & the plasma panel itself may be faulty. u need to replace both boards one by one to get the problem solved. if replacing both boards not solves, then u have to replace the PANEL which is a costly repair.
Sep 26, 2011 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Red flacshing light and won't turn on
What brand, kind & how big is your TV?
How many blinks & what color?
Mar 11, 2009 | Philips 42 in. Plasma TV
LG flat screen tv
if you crack your screen then you will have to change it.and all the blinking colors will disappear.good luck
Jul 17, 2008 | LG 42PX5D 42 in. Plasma HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
