Take it back to the dealer. These small units have a 12 volt DC
generator that is internally converted to 120 volts AC. As such
they are fairly complicated.
Its sure that its missing oil at the engine.Modern engines have a oil alert dispositive. Check oil level,if it is low,just fill with more oil at carter engine.
1. The residual magnetism of the generator core is disappeared or too weak.
2. Excitation circuit wiring error
3. Excitation circuit is blocked
4. Circuit for DC side of rotary rectifier is interrupted
check oil levels as generator will not start if oil level is low. this is a built in safety device on most generators and one of the leading causes of returns to stores />
The 2500w gen. is good for approxiamtly 20a. so, you have to look at the initial draw on start up of a\c, ur 13.5k unit will pull around 10amps under load. Refridge, pulls probably 10a. so, there's the math of it. Check around on my figures, I'm not always right, but, I come close enough to it.
