Question about Olympus Stylus 850SW Digital Camera
Why is my camera making noises and getting coloured lines across the screen when I turn it on ?
The lines then show up on pictures I take
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Red lines
It seems that you have been selecting Panoram view to shoot photos. Go to menu and change the image options and select SHQ or whatever and not panorama. This should solve the problem. Panorama view shows the grid lines all over the screen and it is meant for taking 360 degree panoramic views.
Posted on Sep 06, 2007
nikonian2
dirk boon
  • 154 Answers
SOURCE: Lines on pictures
in what setting did you take this picture ? try a camera reset (it is in the setup ) if that doesn't work try the internal memmory first, than a Xd card
are the pictures it takes only so on the camera or also on the pc ?
Posted on Apr 22, 2008
Anonymous
SOURCE: Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Posted on Nov 03, 2008
Anonymous
  • 70 Answers
SOURCE: Olympus Digital Camera X-775 powers on but shows lines on lcd
Sounds like your CCD/Sensor (eye of the camera)
It can be repaired.
Posted on Apr 20, 2009
Anonymous
  • 919 Answers
SOURCE: Olympus FE-270 has a grey LCD screen, with vertical lines.
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $87.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Jun 17, 2009
Screen flickers and pictures have lines across them on my lumix DMC-TZ3
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Apr 08, 2016 | Panasonic Lumix DMC-TZ3 Digital Camera
Image has lines and pink in colour
This maybe two problems, the pink color hue in the picture and lines from lens shutter problems. Your LCD is still good. You have to replace motherboard and lens.
Feb 07, 2012 | Canon PowerShot A95 Digital Camera
Lines show across my camera when I take a picture
Try the steps below.
Remove the Memory card
try to take picture w/out the card
if there are lines, transfer picture on the computer.
If lines exist when pics are transferred to the computer, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare Z612 Digital Camera
View screen has purple lines across whole screen cant take a pic.
It is bad ccd issue in Canon A95 camera and ccd imager needs to be replaced.
Canon will repair A95 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Good luck.
Dec 21, 2008 | Canon PowerShot A95 Digital Camera
When i take a picture the colour is a purple colour with lines across the screen
The picture element in your camera is faulty. If your camera is under warranty have it repaired or replaced by the manufacturer. If you are outside of warranty then if this is a simple point and shoot camera I would replace it was something newer. If this is a dSLR or professional camera then it might be worth repairing but could be costly.
Jun 16, 2008 | Cameras
Image on LCD jumps
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Apr 09, 2008 | Canon PowerShot A95 Digital Camera
Lines across the LCD screen
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol). Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Mar 11, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
PURPLE LINES SHOWING ON SCREEN WHEN ATTEMPTING TO TAKE PHOTOS
Your camera likely needs a new CCD imaging sensor. It is a cute little thing and is very expensive to replace. I've seen deals to repair any digital camera on eBay and I would check for a local repair person in your area. You can use the search on this site to see who might be close by. I have an A310 doing the same thing.
Jan 04, 2008 | Fuji FinePix S5000 Digital Camera
Lines across picture display.
yes it needs repair. by saying "This doesnt show up before I take a picture" this means their is no problem with the ccd or image taking section. the problem is occouring while saving the photo.you camera needs repair.
Jun 20, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Olympus Stylus 850SW Digital Camera Logo
111 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
