SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
SOURCE: Coleman Powermate Pro-Gen 5000, not been use in
remove bowl from the carb . clean it out ,and check for free fuel flow
SOURCE: have a coleman powermate 5000. Won't start. Laid
Cleaning the carb bowl is not enough make sure you pull out the main jet and clean it out real good. If it starts with starting fluid then it is definitely a fuel problem.
SOURCE: How to remove coleman powermate 5000 generator
4 bolts to the engine then altenator will just pull off may need a puller to get it moving
SOURCE: I have a Coleman Powermate
when the engine sets for a long time the gas can seep bast in to the cylinder and their will be some gas you will need to change the oil and take the spark plug out and air i suggest you squirt a small amount of oil in the cylinder gas in the cylinder can wash out the lube to the rings and cause undo wear and start smoking turn the engine by hand slowly to allow lubing of the rings the gas seepage is most likely caused by a float that's not set correctly you may need to rebuild the carb with a kit around 20 bucks ans easy to do at least the clean it well to remove schlack that gas leaves behind when it dissipates and can cause issues.
replace with fresh gas and run the engine and it will smoke for a couple mins do to the oil in the cylinder remove the spark pug after running a couple mins and clean or replace the engine should be fine following the steps above. hope this helps
