Check that the gas cap vent is not blocked and is working properly for one thing. Also check the oil level most honda engines have a low oil shut down feature.
oil level is fine i will check vent cap. Could the ignition coil cause a hot start problem?oil level is fine i will check vent cap. Could the ignition coil cause a hot start problem?
Yes if the coil is bad they will often times not function when they heat up. When the coil cools off it will start again until it gets hot . It may very well be a coil.Yes if the coil is bad they will often times not function when they heat up. When the coil cools off it will start again until it gets hot . It may very well be a coil.
You can't post conmments that contain an email address.
The service and repair manual with diagram and pictures will provide you step by step help to locate and fix the problem easily and you will get the manual from the given link https://toolsnyou.com/
check for fuel flow blockages including a blocked needle and seat in the carby. Remove the carby bowl and main jet and blow out any obstructions including water.
My first guess would be the fuel pump relay or the ignition module. Look for something that gets hot and fails like a relay or electrical part. When it won't start, check for spark at the plugs and the fuel pressure.
