The mixer connects to the pc via usb or analogue i/p's
the mixer does not connect to the pc speaker
this has to be done with the software you're running on your computer
the easiest way is..plug the headphone o/p into any amplifier line i/p
( amp and speakers or powered monitors ) and forget about the pc speaker ..they're sh!te period ..or you can plug the headphone
o/p into the mixer then the mixer into an amp but this is more complicated and you will need to read up on it
but do yourself a favour and get some small multimedia speakers
similar to these for starters http://www.ebay.co.uk/itm/GENIUS-BLACK-MULTIMEDIA-STEREO-SPEAKERS-SYSTEM-for-LAPTOP-DESKTOP-PC-COMPUTER-UK-/250929417549?pt=UK_Computing_Speakers&hash=item3a6c8f0d4d
SOURCE: behringer djx700 pro 5 channel mixer
When you said radio I am thinking you mean receiver when you say stereo. Have you tried using your CD into the input that you are plugging your mixer into? If you get both sides , right and left of your CD then it is a problem with the signal from the mixer and we can work from there.
SOURCE: Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
SOURCE: I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
SOURCE: My Behringer mixer Eurorack UB802
Here's the manual. page 8 Good Luck!
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000064843.pdf
SOURCE: i want a labelled diagram of behringer 2442fx mixer
Here: http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
