Good Afternoon Friend,
I understand that your Frigidaire washer, model# FWS833A, will not stop filling. I see that you shut the machine off and the water runs onto the floor. I suggest shutting the water off at the inlet. From there I would contact your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water will not stop filling your washer. Hope this is helpful.
-Best Regards-
WP
SOURCE: Washer won't stop filling
The mixing valve that is part of the connector where the hose is attached has either failed or is disconnected electrically.
These are simple to replace and not too expensive.
You may have gotten some debris into the valve assembly which is being held open and is a sealed device.
If this is the case, it will probably not be removable since the valve is trying to close and will only open if voltage is applied.
SOURCE: My washer machine is filling up with water but will not stop
hi..the problem may be due to two reasons.
one is your washing machine will not be fully
automatic,it may be semi-automatic.In that case
the water will not stop automatically after reaching
its capacity.other problem may be there will be some
short in the wire in an fully automatic machine which
could have lead to this problem.
check it out.
thank u.. rate me..
SOURCE: water running out
Is it from the water valve assembly or coming from under the machine? if it's from under the machine you may have a bad fill hose or a bad tub gasket, But I need some more info to help you.
SOURCE: i have a frigidaire atf6000es and while the washer is running water is running out in the floor
Hello Brandy Neal - Often a leak coming from underneath the washer would indicate a leak possibly in the hoses or in the tub. If the hoses are securely tighten then at this point I personally recommend consulting with a certified technician to narrow down the precise issue.
