SOURCE: NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
Custom settings, List print, Print test page, NIC Page.
SOURCE: IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP. That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier. If you can get a control panel screen of the copier to appear. It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
SOURCE: dont know ip for my Sharp AR_C270 i just bought
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1 then a good ip address would be 192.168.0.XXX. xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
SOURCE: sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
SOURCE: How do i change the IP address on the sharp ar 275
press printer button >special key then you can browse through arrow button check there you can see how to change IP address
