I charged my sandisk fuse 8 gb and now the screen is frozen. If i unplug it from the computer the screen is black when I try to turn it on. when I plug it in the computer the screen is lite up but blank
The mp3 player was bought as an xmas present from amazon. I have never had a problem b4 and use it all the timeThe mp3 player was bought as an xmas present from amazon. I have never had a problem b4 and use it all the time
You can't post conmments that contain an email address.
If your Sansa player is freezing, not charging or not turning on, the first thing to try is a reset of the unit. This will normally clear any temporary condition that may cause the player to freeze or not shut off completely, it's a bit like when your PC crashes and you need to re-start it to clear the error. Dec 28, 2020
I went to the sandisk website and downloaded a firmware software to my computer and then downloaded it to my mp3 player. After that it updated the information and it worked again
Your battery is most likely dead to the point where it can no longer hold a charge, which is the reason that when you unplug it from the computer, it dies instanly. Batteries are pretty cheap going up to about as high as $25 and if you get it done at a ipod place, installation should not be that much.
Problem resolved. I just let it sit until battery went down far enough for "Battery" alert to come on screen. From there I put a charge on it and everything works fine now. Probably I should have kept it charged up.
The Samsung YP-F1 has a reset button located under the black Samsung cover plate. It can be gently removed via a finger nail or mini flat blade screwdriver. Once plate is removed a hole labeled reset will be seen. Use something like a paper clip and press in. MP3 will power down/reset. MP3 data is also retained after reset.
