Please help
Another method is to use the AVG Removal tool. Just go to AVG or Google and put in AVG Removal tool and you should find the download for it. This is particularly helpful if you did delete the AVG folder or the previous attempt to remove it failed. In addition, the AVG search bar is sometimes left behind because it either didn't install from an AVG installation or came with some other program. Anyway, the AVG Removal tool from AVG will do the trick.
Follow Rajath steps. He is right.
SOURCE: My AVG is conflicting with my installing Kaspersky.
you might not have uninstalled AVG .instead you could have deleted the AVG folder.
AVg components are still there in the registry.if you didnt uninstall it ,install AVG once more and uninstall it manually.
if its not working remove AVG components from registry
here are the instrucions:
To remove the AVG registry entries, open Registry Editor (Start->
Run-> Regedit). In the registry editor, navigate to the entries
mentioned below,
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\AVG\Avg8
Right click on these entries and then delete them. If you are not
comfortable about deleting registry entries, you can use a free
registry cleaner. If you are using a 64 bit machine, then these are the
entries to be removed.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AVG\Avg8
Once these entries are removed, Kaspersky installation will be
completed normally. Alternatively you can also use the AVG cleaner or
Kaspersky removal tool for AVG8.
