Belt on the dryer
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Replace the timer/control board
SOURCE: Thin Twin Fills up with water and then Hums!!!!!! Dryer works fi
this unit has no belt,,your motor coupling broke,,i can walk you though,,post question how to change motor coupling,,and its not your motor
SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
