Samsung LN40A650A LCD TV Logo
A
Anonymous Posted on May 27, 2014
Samsung lnt4071fx/AXA Completely cloudy gray and white plaid pattern screen
1 Related Answer
Chi Chu
  • 8457 Answers
  • Posted on Oct 31, 2011
SOURCE: I have a Samsung LNT4071fx and everytime i turn it
Samsung tvs models have problems with the tv power supply board alot.That the board where the power a/c cord plug into it.Tries tv unplug,replug the tv back like about and hour later for the tv to do a resetting and a rebooting itself back to the factory setting,tv might work again.If not check the tv front bazel frame display screen panel look at the bottom of the tv for a LED power light indication lite up at all like red or green?If not all or keep flashing none stop.Than it is 100% it the tv power supply board.Must take the tv aparts and checking the tv power supply board carefully for components parts that are called Capacitors.These capacitors parts are very easily to spots if they are leaking or slowly dying.These capacitors dying are alway bulges up on to it tops,never totoally have flat tops.Now all these capacitors parts must be change to fix the tv power supply board to power up the tv again.If u have all the tools and know basic electronic works u should have no problems changing these dying capacitors parts at all.If not tries websites like Shopjimmy.com,Ebay.com to buy a new whole refurbish power supply board for the replacement.
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
We just purchased a 55 inch Westinghouse tv and I've notice with a full white screen what looks to be a plaid pattern. It's very slight with squares that are approximately 4 inches.
This is tiling which should disappear when you select a better resolution on display via remote.you should be at 720p so anything below that setting will pixelate or tile.
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
I am looking for solution for vertical and horizontal lines on the tft screens
Usually bad screens don't have "patterns", they get dead or discolored Pixels but not in distinct patterns. I would think this is more likely to be a failing graphics chip. try this, If you can plug in an external monitor do you still see the Plaid Pattern? If not, then it probably is the screen itself. If it is still there on the monitor then it is the graphics chip. hope this will help you diagnose the problem!
4helpful
Green Plaid lines on Samsung HLR5067wax/xaa-
These are the Tests that should be run to determine which board is bad.You should call a good TV Tech if you are not familiar with this TV.
- The DDP1011 on the DMD board has a feature to display internal test patterns.
- DNle, which is an end port in the digital board, has a feature to display internal test patterns.
- The analog board sends signals to ADV7402 on the digital board.
- The analog board is the first output and the digital board is the second one, followed by DMD, which is the final one.
■ Diagnosis By Module
1. Access Service Mode
(In Standby mode, press "Mute", "1", "8", "2" and "Power" to turn the screen on and enter service mode)
2. Check if there is an error in the DMD board
DDP1011 → TEST PATTERN → Press the right arrow key:
Options of FULL WHITE, BLACK, RED, GREEN and BLUE PATTERN are displayed on the screen.
If "Pattern" does not appear, this is a DMD board error.
3. Check if there is an error in the digital board before the DMD.
When the DMD board has been determined to be error free based on the test patterns:
FACTORY MODE → DNIe → TEST PATTERN normal display: no error in the digital board.
If "Pattern" does not appear, it may be from a DMD board or ATI error or there is an analog board malfunction.
4. Check if there is an error in the analog board.
Check for a power signal from the analog to the digital boards
Part of my lcd tv screen is "blacked out" and another part has a plaid pattern. About 3/4 of the screen is visible for watching tv.
This is the problem with the onboard capacitor get it replaced it resolve the issue...............
Blue screen appears on my samsung camcorder
SOUNDS LIKE A BAD CCD.. SAMSUNG IS KNOWN FOR THIS PROBLEM WITH THIS MODEL.. WILL YOUR UNIT RECORD SOUND BUT NO PICTURE? IF IT DOES IT IS THE CCD ..CHARGED COUPLER DEVICE
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
