Paper feeds from the paper tray but will roll up into the upper position where printing is done.
Check the green paper-size end guide inside the paper tray, it may be too far forward. There's a mark for letter-size paper (LTR) and I have my guide set right at the mark even though it seems it ought to be shorter. Be sure your paper is back up against the mark. You might also buy some different paper and see if that's the problem. Sometimes cheap paper will not feed right (I use Staples copy paper in my ink jet and laser printers).
SOURCE: Paper jam Brother MFC-215C
Thanks, your suggestion led me to the solution, the jam not in the rollers or a senser, but it's in the dock of the printer head, when the printer head moved across, I shone a torch into the dock and saw a black thing, so eventually pulled it and realised that it was paper and it had been dyed black by the ink so that's wht it would be hard to spot!!!! Thanks again
SOURCE: brother HL-2040 laser printer
brother laserjet HL2040 printer
tonner error / paper error / continued rolling
what is the problem
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
SOURCE: paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
SOURCE: my brother mfc-6490cw printer keeps
my brother MFC-6490CW keeps coming up with an error message 'cannot print 70' how do i solve this?
