White spots
SOURCE: mitsubishi wd 65735 - blinking green LED on front
hello,
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Power supply board just die.It can be
dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power
supply board for the replacement.
Good luck..
SOURCE: Hello there, I have the
If the lamp light blinks yellow, then the first thing I would check would be the filament of the lamp. It is not completely blown into shrads, but it sounds like the filaments is fried. Please check it and let me know.
Sai.
SOURCE: bright white spots on mitsubishi wd-73833 I just
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
SOURCE: White spots on screen Need DMD
This is something of an urban myth....The "DMD chip" is actually the LCD display IC for the set; yes I have seen some listed on EBAY---still a myth----they are replaced (when a light engine is rebuilt in a space age lab or environment) under exacting conditions----if positioned a micron off in any direction picture will be tilted in some way---this is also not like changing spark plugs in a car, if you have a optical engine issue like spots etc, either get a rebuilt engine from Mitsubishi or buy a new set.
They usually require some parts for old engine (mounting brackets etc) be installed on new or rebuilt engine.
I did see the "chip" for another model listed on ebay today.(100.00 PLUS)
I understand the engine is expensive, I replaced a lot of them when the sets were in warranty---more Mitsubishi than any other brand with Samsung a distant second.
I am sure Mitsubishi does not offer the part for sale--they want to sell a tested rebuilt engine only.
I wish you luck but have little hope you will find a "part" other than the whole engine.
SD TECH
SOURCE: How do I repair white dots/dead pixels on my 3
You have a bad light engine. It is available at encompassparts.com for retail price of $749.10. Call 1-800-638-3328. Consumer not in business could be higher price.
