It is possible that the water softener is not functioning properly and causing the water from the refrigerator dispenser to taste salty. Here are a few things you can try to fix the issue:
- Check the water softener settings: Make sure the water softener is set to the correct salt dosage and regeneration frequency. If the settings are not correct, it can cause the water to taste salty.
- Check the water softener filter: The filter in the water softener may be clogged or dirty, causing the water to taste salty. Clean or replace the filter as needed.
- Check the water softener resin: The resin in the water softener removes hard water minerals and can become exhausted over time. If the resin is exhausted, it can cause the water to taste salty.
- Check the water softener bypass valve: The bypass valve allows you to bypass the water softener and use untreated water. Make sure the bypass valve is not accidentally left in the bypass position.
If you are unable to diagnose and fix the problem on your own, it is recommended to have a water treatment professional take a look at the water softener. They will have the necessary tools and expertise to properly diagnose and repair the issue.
