Load noice when drying
The squeaking is likely coming from the drum rollers and the grinding is likely coming from the drum rubbing against the door frame. This can be caused by a badly worn roller or damaged felt slide. A repairable condition that should be considered before throwing out your dryer. You can obtain a kit for this at your local appliance parts store or order on line. If you or know of someone that is pretty handy, you can install the kit, and a new felt slide for less than 1/3 the cost of replacing your dryer. Remember to inspect the drive belt to ensure that it is not torn or about to break.
