Ultra wash model 665
SOURCE: Lower spray arm does not turn or spray.
HI It might be a broken sump assy. Which is the part under the lower are.
Without testing it myself I can not tell you what is broken but....
I can help you get an ideay. there is a microswithc in it (#27) which sometomes goes bad but to make it easy on you HERE is the link for
LDS5811ST
LDS5811WW
you should be able to rebuild the sump assy with no problem
It can also just be stuck. The only way to find out is to open it and take a look
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
SOURCE: Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
SOURCE: Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
