300 cd player cdpcx350 won't spin in disc playing section indicates table error
SOURCE: TABLE ERROR SHOWS IN WINDOW
What probably happened is that some CDs fell off their tracks and are blocking the main wheelhouse from turning. To solve this you will need a philips head screw driver. First unplug the machine. You will need to remove the top of the unit (which slides off towards to the back) after removing the 9 screws (2 top, 4 side, and 3 top back). Once you slide off the cover, you will expose the wheelhouse and you should see the CDs that fell off. Simply take the cds out. Once you have taken out all the CD that came off the tracks, slide the cover back on and screw in the 9 screws. The CD player should work again. This worked for me and hopefully will work for anyone encountering this error.
SOURCE: CDP-CX300
Get a service manual or pro to get this taken care of. It's a timing issue..accordianman
SOURCE: turntable is wacky
try loading half your discs on one side of the turntable and the other half on the other side and see if that solves it.
SOURCE: sony cdp-cx335es
no fix and no help from your site I paid for the premium service and have heard nothing from you or your so called expert tech's I want my money back
SOURCE: when power up table spin both directions theb
the sensor for the table cna't read the table movement. it's an optic sensor and it might be dirty or obstructed. you can open up the unit and blow out any dust with canned air. check the sensor for damage.
