Without any more information regarding the specific symptoms, diagnosis will be difficult. However, assuming that your refrigerator has a factory built-in ice maker, there are several items to check:
1. Is there water flow to the icemaker? If not, check the water supply line (small tubing) and make sure it's not clogged. Disconnect it and blow it out, then reconnect.
2. Check the small saddle valve on the water pipe where the tubing to the refrigerator connects. If it's full open, then it's possibly blocked with calcium buildup. Close your main water supply valve, remove that saddle valve and replace it with a new one. Before doing so, make sure that the hole in the water pipe is clear and full open. It may also have some calcium buildup. If so, simply drill it out with an appropriate sized drill bit.
2. The solenoid valve which activates water flow to the icemaker may have stopped functioning. Check the electrical connection to the solenoid valve and ensure power is getting to it. If it is, then the solenoid valve most likely needs to be replaced.
3. Check the manual for your refrigerator. It should include instructions on how to bypass the automatic function and *manually* start the icemaker.
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
