Kyocera KM-1505 Copier Logo
A
Anonymous Posted on May 29, 2014
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
imran Tabish
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 30, 2014
imran Tabish
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
7563
Points
5
C4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
donovin mclain
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert 210 Answers
  • Posted on May 29, 2014
donovin mclain
Kyocera Expert
Level 2:
New Friend:
Cheetah:
Answers
210
Questions
Helped
108090
Points
231
3 Related Answers
Anonymous
  • 11 Answers
  • Posted on May 12, 2010
SOURCE: How to solve error A3200 for Kyocera KM-2035
clean the optic section
Anonymous
  • 241 Answers
  • Posted on Jun 09, 2010
SOURCE: How to solve error c6020 for Kyocera KM-2035
The C6020 is a fuser error code and should be checked out by a Kyocera tech.
Anonymous
  • 6 Answers
  • Posted on Mar 19, 2012
SOURCE: My Kyocera KM 1635 / 2035 displays error message: error call 600
Needs a service, either call your photocopier service company or find one on google.
How can i fix km-2035 error c4000
c4000
The Problem:
signal turning on
Causes:
terminals.
2-Defective polygon
motor.
Replace the LSU.
3-Defective engine PCB
Replace the engine PCB and check for correct operation.
This wat the service manual say about this error code but as Tech i recommand for you to do this steps before changing any part and this 60% could fix your problem.
First of all open the back of your machine and make sure there is no cable connector is lose, specially those cables that connected to motors, unplug those cables and plug them again, also make sure that the paper fader cable is connected well. after this put the machine on and off and do this steps:
In the operation panel hit 1087 twice, and this will take you to maintenance mode , then select 906 and hit start, look for the words in the screen, hightlight it and hit start again, the machine may be will tell you put the main power off and on, do this and you will be ok.
hope it helps
Caller service C6000 in kyocera km 2035
Fuser heating Error
enter into programming
1087 1087
Then enter 163 then Press Print Key
1helpful
2helpful
Mery clear for kyocera 2035
How to service mode of copier kyocera km-2035
5helpful
2answers
12helpful
How to solve error c6020 for Kyocera KM-2035 copier? it has stopped
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
