Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Dewalt dcd950 chuck
Removal
  • Dewalt Master
  • 2,012 Answers
Its is about a 2 years modified the XRP chucks In Netherlands the model 950 is not QS made for europe but all the XRP machines have had a special solide looking Chuck For the original Chuck there was a special tool to remove the chuck the gearbox must be open to and a special N119912 a complete unit of repair tools to remove the chuck and replace , BUT the new modificated repair is by get a normal standard keyless chuck , asked them for about the modification because of the older repair tools and chuck http://www.2helpu.com/world/map.aspx it's about much more cheaper to choose for modification the N119912 is possible renumbered thats possible the right same tool because of the model DCD 950 is not selled in Netherlands . the DCD945 instead of but it means the same kind of modification .
Posted on Oct 06, 2015
6ya staff
SOURCE:
Gigatech
Rafael Ortiz
  • 259 Answers
SOURCE: dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Posted on Mar 05, 2008
smjdragonfly
Shaun M. Johnson
  • 79 Answers
SOURCE: Having problem to remove chuck to replace it on dewalt dc988 18v
Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Please rate me
Posted on Jun 18, 2009
Testimonial: "Thank you very much. solved my problem last year or so...George"
rowdy45176
David Ford
  • 2176 Answers
SOURCE: got a broken drill chuck i cant get off (Dewalt)
first remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
Posted on Jul 02, 2009
damienl74
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
wireguy212
danny herget
  • 1627 Answers
SOURCE: I have a DC900 dewalt drill and the chuck requires
Open the chuck as wide as it will go and then remove the machine screw from it,it's down inside the chuck.Now,put a 5/16 allen wrench in the chuck and tighten it.Hold the drill with the chuck away from you and hit the allen wrench with a hammer,with the wrench to your right and making the hit drive it downward.Spin it off with your fingers from here,hope this helps.
Posted on Jan 29, 2010
How do i close the chuck on a dewalt dcd950
The DCD950 was DeWalt's worst chuck design. This chuck has no chuck screw, they loaded the spindle with locktite and put them on. Consequently, the chucks are nearly impossible to remove. DeWalt made a tool for this purpose, but it costs almost $90 - the only alternative was to replace the gearcase assy but they just made it obsolete, no longer available.
There is a conversion kit but the problem remains, you still need to be able to remove the old chuck.
We have used a metal cutting saw to cut the chuck off - about the only thing that works Conversion Kit N422782 for DeWALT Power Tool eReplacement Parts
Sep 25, 2014 | Dewalt Dcd950 Hammer Drill Uses Dc9096 Or...
How to get the chuck off a dcd950 dewalt hammer drill
Only the screw in the centre of the chuck would be l/h tread, the chuck should be normal thread and come off in an anti clockwise direction. Please confirm drill model number.They did a version where you needed a service tool to remove it and refit. It is torqued on.
Nov 15, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Removing chuck from dewalt dcd925
open chuck and look in the bottom of it (chuck)there is probably a screw there. think it will be left hand thread
Oct 25, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Chuck removal no screw down in side to take out what now?
you attach a 8mm (5/16") and long one allen key and you use a heavy hammer in order to place a strong torque (force) on the chuck in order to be unscrewed....
Aug 15, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
DCD 950, How do you remove the chuck
open up the jaws ,look in the now open area there is a standard screw at the base remove it chuck will come off ,,some are stubborn,,
Jul 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Can not remove the chuck to replace
Take this link to you tube and watch a repairman remove a chuck while giving instructions.
http://www.youtube.com/watch?v=usC8unA5RiA
Jan 05, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Can't get the chuck off my DCD950
if trying to remove the keyless chuck/open chuck and down inside is a hex screw useing a hex wrench place long end in screw and give the wrench a sharp rap with a hammer to break loose/....(not sure if dewalt has left or right hand threads)and i have had to rap a drill with a rag and place in vice to help hold it.......hope it helps
Dec 30, 2010 | Dewalt 18 Volt Compact Drill Kit
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
391 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
