A CI is an to high amp draw on the motor. In my experience it could mean your motor is bad, or motor control board is at issue. The only way to really check is to have an amp meter to see if the motor is drawing to many amps.
285917 MOTOR ABOUT $250
8571359 CONTROL BOARD ABOUT $200.
The biggest issue, is you may also have a transmission locking up, basket drive issues, bearing issues, etc causing the motor to pull the high amps.
SOURCE: kenmore calypso model 11022086100
Thermal overload protector is mounted on the motor. Normally the motor is replaced.
