Where can I find suitable replacement remote for my Toshiba model 61X81 television that will give me most of my television features.
I was given this television but they did not have the remote and I was watching the demo and the remote that I does not even come close. Short of buying a exact model replacement from Toshiba, or eBay , is their a suitable 'clone' that will do the job.
Without its original remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To release the panel lock, you should have a remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
You should have its remote control to select the inputs.
Depends on the model. Some models have energy saving feature
The unique energy saving feature is called 'Automatic Power Down'. This means the television will self-switch into stand-by if no television remote control commands are received within 4 hours. This feature is an energy saving solution for situations where the television may be left unattended for extended periods and has been enabled as the default setting.
You will see an on screen warning prior to the automatic shut down. Automatic shut down will be averted by depressing any key on the television remote control.
Use of automatic power down functions will be progressively introduced to future models in an effort to reduce energy consumption and greenhouse gases.
If you would like to disable this feature you may follow the instructions below (depends on TV Model)
1. Press theMENUkey on the remote control.
2. Press theright arrow keyand highlightSETUP.
3. Press thedown arrow keyand highlightAutomatic Power Down.
Hello
Please contact the nearest Toshiba Authorised service center in enquire there. The will lead you. Sometimes, they may have its original remote control with them for sale. Note the model number and give it to them. OK.
The remote control for this model is no longer available through Toshiba. You can operate the set but will not be able to use the picture size features. You should be able to work the main functions and also access the picture and audio on- screen adjustments. If you find a vendor that happens to have miscellaneous remotes, the remote number is CT90164.
I hope this helps,
Skyassoc
Hi I have the same model. you will need a remote that came with it...
u need to access the menu button on the remote and use direction cursors to select special features.
once highlighted press down cursor to select "panel lock" then select right cursor to switch off (as it will be on) then exit menu.
The more important question is what kind of remote are you using? The codes for a given manufacturer are based on the remote control itself rather than the brand of TV. The codes are what are known as proprietary to the remote manufacturer. If you give me the brand of remote I might be able to help...
