Can it be fully restored past the activation without knowing the previous owners info?
SOURCE: 3g not working on apple Ipad
As far as I understand it the ipads that have just been released are wifi only. 3g are available from late April, see the www.apple.com for details.
SOURCE: Apple Ipad screen isn't working
If the issue persists after a restart, there may be an issue with your digitizer / touch panel. Apple willhelp you with this because it is so new. However if you dropped it in water (etc.) and if apple doesn't replace it for you, You can get the digitizer at iPad Repair and there is a guide that shows you how to put in the part at Electronics Repair Guide.
Testimonial: "thanks"
SOURCE: Syncing Outlook 2007 email with iPad
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
SOURCE: I cannot access old Outlook (2007) emails on my
1)Press settings icon (the one with the cogs)
2) than scroll to Mail, Contacts, Calendar and press it.
3) Find your email account you want to modify and click it
4) find the section on the bottom that says "Mail Days to Sync and press the button
5) Now, you have limited options there, but you can pull email from 1,3 days or 1,2 weeks, 1 month or No Limit. If you click no limit it will pull your entire inbox. So, I might be careful in saying it will drain battery power. And or take room on your ipad away. So, if you have old emails with big attachments, be weary. Plus, depending if you are pulling all this mail over 3G you should take note of your data limits.
Hope that helps.
SOURCE: my ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
I have tried restore and reset, but neither will go past the activation page. The Ipad is asking that I activate using the original owners computer that was used at set-up and their email. I do not know how to contact this person, nor do I have her original computer used to activate the Ipad or her information. How can I activate this Ipad and erase the original information used when bought brand new. Can I get this Apple Ipad A1458 to activate using my credentials and operate it as brand new?
