SOURCE: Password
You can use the net user option. Go to this site and you can find the answer. http://support.microsoft.com/kb/149427
SOURCE: lap top screen is black
If you are running with XP try switching the unit on and pressing F8 while the computer is booting up
This should put you into Safe Mode
If that works go to Start , Accessories, System Tools ,System Restore and if the shop did the right thing when they built it you will have the System Restore function running
Ask the machine to do a System Restore and it should give you a number of dates to restore to, pick on that is a few days before the last update and let it roll
SOURCE: black screen after turn on
That "Blue Screen" is also known as "Blue screen of Death".
The problem is due driver compatibilty or unstablity.
Try to boot your system to "Safe Boot" by pressing F8 during startup.
Select "Last know good Configuration that works"
Check if it can take you to desktop.
Unstalled the wi-fi driver and reboot.
If the above procedure fails, again
Select "Safe boot"
Now create a restore point and download the lastest version of your WI-Fi driver and installed.
This should work fine.
Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
SOURCE: No built in microphone Acer lap top
Is there a question here? There is a port on the back allowing a mic to be plugged in. I'm guessing that's the question, right?
Testimonial: "very clear and helpfull"
SOURCE: how do i reboot m y 5515 acer aspire lap top
Click the start button (Or the windows icon - typically lower left on the task bar). Choose Restart. If you can't find that, choose Shutdown, once the laptop is off, press and hold the power button till you see the power come on.
