Question about GE WBSR3140DW Top Load Washer
Ge washer no water no spin just a wash and drain cycle
Ge washer wjrr4170e6ww does nothing but wash and drain. the knob striped cheap plastic can still select settings. worked fine that way now have just wash and drain. all my selection are gone no matter where i put it. motor inverter board ststus code reads normal. i think it is cheap plastic gears in the timer asm (ps270259) i could use a little solving this thank you.
6ya staff
SOURCE:
JULIANFIX
ALBERT GARCIA
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
mikedurland
Mike Durland
  • 481 Answers
SOURCE: Drain pump/motor not draining.
actually it sounds like there was or is something in the water pump (like a string or metal underwire from a bra). before replacing the water pump i would look inside it and check for foreign objects.
  1. unplug the machine, but leave other hoses connected
  2. use a butter knife or putty knife to open the front panel; at the top seam between the top panel and the front panel is 2 metal clips (about where the edges of the lid are). push these strait in to release the front panel.
  3. once the front panel is off then you should see the water pump on the right side. it has 2 large black hoses and 2 wires attached to it.
  4. take off the water pump (two 3/8 bolts) and look inside it.
some pictures borrowed from fixitnow.com, allpar.com, applianceaid.com and repairclinic.com
  • if you need to buy a new pump, then they are around $50 at repairclinic.com
  • or shop around; GE Washer Pump part # WH23X10013
  • here is a cheap one on ebay:
http://cgi.ebay.com/GE-WH23X10013-Washing-Machine-Washer-Water-Pump-Motor_W0QQitemZ170239837032QQihZ007QQcategoryZ20714QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
let me know if you get stuck
Mike
Posted on Jul 30, 2008
Steeler Ed
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
Frank Meola
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
My washer fills with water and drains but does not agitate or spin. The belt is fine. This washer is one year old.
The top of the agitater should only turn counter clock wise by hand. If it free wheels the plastic dogs between the 2 halves of the agitator are broken. Cheap fix.
Jun 28, 2010 | GE WBSR3140DW Top Load Washer
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Washer fills, does nothing during wash cycle, then drains. Washer is a 587.15252402. It is also very hot inside
sounds like a GE . MY BEST GUESS IS THE CAP UNDER THE AGITATOR IS STRIPED . REPLACING IT SHOULD SOLVE YOUR PROBLEM
Aug 28, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Washing machine quits after filling
I believe you need a new belt. The weight of the water is to much for a loose belt that is connected to the agitator.
2. Make sure nothing is blocking the safety shut off located on the machine.
Jan 19, 2009 | Washing Machines
GE Profile Washer - Model WPS Q416OT2WW - Knob repair
Knob should have a small plastic cover in the middle that just pops off. From there you will see a nut or pin holding it in-place. Why are you replacing the timmer? (Timmer is a VERY last resort when working with washers) I'll check back later around 5pm
Jan 22, 2008 | Washing Machines
GE washer - Excessive shaking in between phases
how old is the washer? depending on the age and the model the problem could be different things
Jun 23, 2007 | GE WBSE3120B Top Load Washer
GE Washer wbsr3140d5ww water problem
Hello Chad
Welcome
Sounds like the cold water knob or switch is not switching and may be faulty.
I have a problem with my washer
For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine
The cold water does work though because if I change the washer to a later cycle cold water comes out just fine.
So it almost seems like its the timer knob
any ideas?
Thanks
Please remember to leave a rating
Jun 04, 2007 | GE WBSR3140D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
162 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
