I have been using re-filled HP toners and now all of a sudden the printer wont work and gives me the error of non-HP supply in use. Can I bypass this? It will make copies but wont print or scan.
SOURCE: remove and check color cartridge error
i was woundering are these new cartages or refiled ?
cause our wont work with refilled caratages
so this is how i found that out !
Issue
After you install a print cartridge, the scan, copy, and fax lights begin to flash at the same time. The printer will not print. One of the following error messages may display on the control panel:
Solution
Follow the steps below until the above issue is resolved. All of the following steps may not be necessary to resolve the issue. When the lights stop flashing, the issue is resolved.
NOTE:
Either one or both of the cartridges could be causing the problem.
Step one: Remove, inspect, and reseat the problem cartridge
The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
NOTE:
HP cannot guarantee the quality of remanufactured or refilled cartridges.
Step two: Clean the problem cartridge contacts
If the steps above did not solved the problem, follow the steps below to clean the electrical contacts on the print cartridge and in the carriage in the printer.
Step three: Repeat reseating and cleaning steps
If the problem is not solved, repeat the reseating and cleaning procedures above.
SOURCE: hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
SOURCE: hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
SOURCE: 10.10.00 non hp supply installed
If you are using a re-manufactured toner cartridge, this is a common error. There is a chip inside HP manufactured toners that communicates with the printer; oftentimes, cartridge re-manufacturers use third party toner cartridges which lack the chip. You can usually clear this error by pressing the checkmark button several times; the only downside is that Econo-mode will usually not work.
SOURCE: I have a HP Photosmart C6180 All-in-One printer.
A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev 1. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen) 2. Press and release the ?OK? button. 3. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 4. Press and release the ?OK? button. 5. Display should say ?Hardware failure status: Clear. Press OK to clear?. 6. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 7. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK.
