Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: Frigidaire Affinity - Code DR - Washer wont start
Dear G.Arnold,
ngfam at you service
When you get an error its best to call service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: Frigidaire affinity front load washer,
Hi PAU
error means cycle has been interrupted; it is not a right error though. Please
follow these steps: 1.
Wake the washer by pressing any button. 2.
Wait 5 seconds. 3.
Press and HOLD the Start/Pause and Cancel buttons
simultaneously. As long as the buttons are held, the failure code will appear
in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator
lights will flash. Post
back with the complete error code for further assistance. Hope this
helps.. Daniel
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Hello friend, thanks for your post!
From my understanding you would like a list of error codes that apply to your Frigidaire washer. Is there a specific error code you are searching for? I was unable to locate a list of all the codes that would be available within your washer, ATF7000E. With additional information I would be able to assist you further. -Matt
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
