Plug either a powered monitor or amp and then speaker into one of the aux sends. Now adjust the monitor mix using the appropriate aux send pot on each of the channel strips you want to send to the monitor. Think of the aux send pots as faders for the monitor mix the same as the main fader for the ain mix.
1st....the output section, "M" stands for mono. The A&E does not have "monitor" sends per say but instead calls them "Aux's." Adjust the proper Aux for the input channel 1-16 and use the Aux output section (row of knobs above output sliders) as the master volume. By using Aux 1-4 (and with more amps) you could send 4 discrete monitor mixes to four different band members. Bass likes his monitor strong but doesn't want to hear other members while guitarists want to hear only himself and the singing drummer...etc.
If you're trying to get a monitor feed from this unit, use the "aux" send. Connect the "aux send" to your monitor amp. The main Aux fader provides "master" level and the "aux" knob for each channel allow you to "mix" your monitor signal.
That's basically normal actually...however it depends on which aux send you're using. If you use aux 1 for the effects, you can use the pre/post switch on the master aux 1 send to switch it to pst fader....now your mute switch should kill the effects as well. Aux 2 is good to use for monitors where you don't need to return them to the mixer.
No there is no special cord. The aux you use for a monitor should be pre fader( that means the signal comes before the volume slider) turn the individual slider all the way down. Talk into the mike at the volume you would be singing at the loudest. Adjust the gain of that chanel up untill the clip light comes on. Now back it down so it dosent come on at your loudest. Now pick the aux you want to use. Turn it up 1/2 way, turn up the master aux send coresponding to the channel aux number 1/2 way you should get sound. If it's too loud turn it down if you need more turn it up. If you have any more questions, give me a call at the shop.
It appears that AUX6 is default factory strapped as POST FADER. If you want to change that you will have to disconnect jumper L to A for all channels you want the AUX to be pre-fader and instead connect K to S for the option jumpers. I don't know if this requires soldering or whether they are push on jumpers. These should be available in the back cover. In ADDITION you will have to run the switched pre/post fader switch in the PRE position which will make ALL AUX's that are strapped this way PRE FADER.
It looks like using the GROUP output to drive the external FX and then bringing that back into the EFX return is about the only thing you can do in short of putting the effects after the main outputs then it would be on everything.
