I have tried to put the make and model in the query but it seems to only want to accept the T8 details, my treadmill is the HyperExtension JN1360 model number 50000I have tried to put the make and model in the query but it seems to only want to accept the T8 details, my treadmill is the HyperExtension JN1360 model number 50000
You can't post conmments that contain an email address.
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Based off the information you provided your Electrolux washer is displaying "0.00". Typically any error code that is labeled "00" means no error code stored, which means it's a false error code. I would recommend performing a reset on your washer due erase any false error codes. You can do that by disconnecting the power from your appliance, by either unplugging it or flipping the household circuit breaker, for ten minutes.
If this step does not help resolve the problem please provide me with the new error code or if your display continues to show "0.00" I would suggest seeking assistance from a professional to come out and properly diagnosis your washer. I hope this information is helpful. -Matt
Err 11, Err 12, Err 14, Err 17 Dirt or a scratch on the disc stops the laser beam from being able to focus. Dirt or a scratch on the disc hinders the track
Clean or replace scratched disk.
There ya go, clean or replace the cd that is displayed.
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
The "Busy" code will be on when the camera trys to use a flash and waiting for its charging action. Upon completion of charging the mechanism returns a signal to the camera to fire the shutter.
That means now your camera has something wrong on the flash unit and the camera waits for some certain time frame to finally determine it cannot complete a photo-taking command.
An "ERR 99" denotes that this kind of error has not been encorded explicitly and needs investigation services.
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
