Electrical Supplies Logo
Bob. Jenner Posted on May 30, 2014
How do you stop generator from stalling under load
  • Bill May 30, 2014
    Hi Bob. Jenner, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? How big is the generator, and what are you trying to run?
Coli N Evans
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Jul 14, 2021
Coli N Evans
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
2132
Points
12
Clean out the carbretter , add new fuel
Bill
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on May 31, 2014
 Bill
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
4755
Points
23
As you have not provided me with the information I requested I'm going to have to take a few guesses here Bob. You could be overloading the generator. You can't run a 10,000 BTU air conditioner off of a 1000 watt generator. You need to look at your load, (what you are trying to power), and determine how much power it needs. Almost everything has a tag somewhere on the device. Most don't give watt requirements. But they do tell you, how many amps the device pulls, as well as the voltage the device needs. So you need to do some math here. Volts X Amps = Watts. So if we have a 120 volt device, that pulls 15 amps, we need 1800 watts to power it. But it gets a little more tricky than that. Motors are often rated at what they pull while they are running! But it can take two or three times more power to get them started. Example... A motor rated at 10 amps, using 120 volts will be 120 X 10 = 1200 watts. But it could take 2400-3600 watts to get it running. So in theory a 3000 watt generator may die before it can start that load. Heating elements are also power hungry! Let's say you have a small 800 watt generator, and your just trying to run a simple coffee pot! Well the heating element in a typical coffee pot pulls 1000-1500 watts. A hair dryer or microwave oven rated at 1000 watts, is the power they produce, not the power they consume! So a 1000 watt microwave may pull 1600 watts of power to run. Most non US generators are highly over rated as well. I certainly would not trust a Harbor Freight 3000 watt generator to actually put out 3000 watts of power. Not that they are bad units, I would expect their numbers to be under PERFECT conditions. Temperature, humidity and altitude also play a part! Your 3000 watt generator is going to put out more power at 50 degrees, at sea level, than it is at 7000 ft in the mountains at 100 degrees. So my "guess" Bob, is that your just asking more from the generator than it can produce. Picking out a generator is not as easy as it looks. "Hey that one is $1000 and this one is $300! They both make power! What's the difference". The difference is what do you need to run! "Heck I'll just get that 50,000 watt unit"! Yeah you can do that too, but you will never use that much power, and you will burn way more fuel than you need to. My other "guess" is that you have a governor issue on the engine. As load increases the gov will throw more throttle to the motor. My generator has an option to run full speed or on the gov. So it will idle and burn less fuel while I am hammering in a nail, then go to full power when I trigger a saw connected to it. Lot's of factors involved here Bob.
1helpful
Why would cause this welder to load up excessively to the point of almost stalling the motor?
a short or a very bad bearing seizing up or throwing the axle out of alignment under load could do that
My generator start the breaker trips under load and stops engine but with out load no trips
First check the load and grounding, you will need to measure the amperage draw wih an ammerter, also check to see if it trips when a large unit like a motor or air conditioner starts, it may not be able to handle the inrush. Also be aware that if your breaker is a 30amp does not mean you can pull 30amp you can safely constantly draw 80% of that. Also check your grounding of the equipment you are powering.
Pops coughs and stalls when put under a load
Chk air pipes & filer, and plug/s, are clean.cheers
Generator w/nat gas conversion kit sputters
THAT SOUNDS like a VERY LEAN condition. The exhause glowing is because its so lean. The stalling the sputtering. OPEN the gas valve more WHILE its running. With a load if possible.. If you have a tri fuel kit like I do, going from propane to nat gas I need to open the load block (gas valve) 2 turns more .Then it starts and runs great.
My Impact 36LP runs fine under small load (lights/TV/Fridge), however when I turn on my RV A/C unit the generator slows and stops after about 2 minutes. JD
the generator is rated for a certain static load. it may also have an intermitent loading. when the critical load value is reached the engine slows down because the load is too much. add together all the wattages of your loads to get a final load in watts and check against the nameplate wattage of the generator.
3000 watt yamaha generator is really hard to start and when started it stalls under load.
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
Em 5000sx runs but stalls under load. had a hard time starting have to play with choke. drained gas cleaned carb finally got to run. now when i plug something in it stalls under load
GX340 engine always works best with complete carb kit that at least contains main jet, needle valve, main nozzle and orings. It is hard to clean varnish/crud from carb and soaking may make it worse. Kit is not expensive. Check ebay, less than $10. Before you change any parts make sure that your cap is venting properly. Many California gas caps (tall chrome gas cap) may cause fuel lock. Also check that muffler is not restricted with carbon. Good luck
2006 Mercury Mariner V6 4WD. Sporadic stalling when stopping
One of the most common causes of stalling like that but not showing any fault codes on many types of vehicles is the IAC valve, or IAC motor. (same thing) It's mounted on the side of the throttle body near front opening and it controls engine idle under load conditions such as applying brakes, turning wheel, AC on, basically anything you use in vehicle that puts any load on the engine, which will make RPM's drop at idle, that valve, steps it up to where it should be to eliminate that. I'd remove it, get a can of throttle body spray cleaner, and clean pintle (pointed part) and the port (hole) it came out of real good, then re-install it & see if problem goes away. If it goes away, then returns before too long, replace it with a new one.
1helpful
Ginne stalls under load
Likely that your governor has creeped out of tolerance. Very common with Emerald line of generators. Try to borrow, if not already have one, a multimeter that is able to read frequency and voltage. At no load, frequency should be 62 or 63 hertz. At full load, frequency is going to be around 57-58 hertz. Voltage at no load should be 127 or so, full load should drop down to around 115 give or take. Adjust governor for faster engine operation for low voltage / frequency, slow down for too fast frequency or high voltage (though that is likely not the case here).
Problem with Emeralds is that the governor spring rubs on bracket, and also has a tendency to stretch. If this is the case, adjusting governor will be near impossible between full and no load.
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
