Why do I keep getting Add paper in cassette message
SOURCE: Bulk feeder keeps jamming
It might be the tray Feeder not placed properly or the printer needs a service if not done in the last six months. Contact to your nearby Repair shop and Service centre.
Thanks
Scott
SOURCE: Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
SOURCE: Message says to add paper
There is a sensor with a flag that may need to be cleaned or replaced. Take out the tray and put the printer on its backside (so you are looking underneath the printer. There is a flag and sensor visible. Clean the sensor. If that doesn't work, replace.
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
