Camera only takes photo in video setting
SOURCE: can't switch from photo taking to photo review
Assuming your LCD still works, go to the camera settings and reset the entire camera to the default factory settings. This will help you determine if it is a hardware or software problem. If you are still unable to get into the photo review, you may have a hardware problem.
SOURCE: Mode Selection Fault
Hi
Your mode position switch could just be damaged or the switch on the outside of the camera might not be properly lined up with the switch on the inside. You have to open up the camera body to see what I mean, its not hard, just make sure you take out the battery first.
If you need the mode switch, its pretty easy to take off, I just pulled one off an SD300 to see whats involved and its pretty simple.
As for international shipping... Im starting to do it more, but only via US Priority Mail International which is $12 for a flat rate envelope. I just don't like stuff disappearing during transport and that's why I don't like shipping to the other side of the globe.
If you need the parts please let me know, we will get the shipping figured out.
Good luck from: Darntoothysam com
Thomas
SOURCE: CAnon SD400 sticks in movie mode
There are 3 mode buttons that worked their way out.
They need to be replaced.
SOURCE: switching to movie mode automatically even when on camera setting
ok. I took off the 6 small screws holding it together, inspected it to see if it was anything obvious and easy and but no. I seen the small switch inside and figured it was at fault and needed to be replaced. (yeah right! like that could be done) then put it back together and so far the problem is gone. now i just have to wait and see if it stays that way. so far so good.
SOURCE: LCD screen is black when in photo-taking mode
hi
try chaning the menu options to LCD instead of View finder and things should get back to normal
if you are not too keen about the setting then you can just reset the settings to factory defaults and this should work again
hope this helped
cheers
pls rate the solution, thanks
