Question about Samsung SCH-a870 Cellular Phone
How do i get 4 digit code - Samsung SCH-a870 Cellular Phone
    Habit-Forming:
  • 111 Answers
For the phone lock?
Posted on May 31, 2014
6ya staff
SOURCE:
I'm looking for a 4 digit code to RCA converter box
see the link
RCA Digital TV Converter Box Remote Codes Codes For Universal Remotes
  • RCA Digital Converter Code = 52325
  • Sansonic Digital Converter Code = 52348
  • Sylvania Digital Converter Code = 51563
Mar 13, 2018 | RCA Televison & Video
Ineed a code for tv converter box,What would the code be for a tv converter box ?
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jan 11, 2017 | Televison & Video
How to enter a radio code
4 digit code can only be entered when 4 dashes appear
Or ----
To enter code 1134
Button 1 = first digit of code press once =1
Button 2 = 2nd digit of code press once = 1
Button 3 = 3rd digit of code press 3 times =3
Button 4 = 4th digit of code press 4 times = 4
Press and hold AS button until radio activates
Feb 03, 2016 | 2005 Nissan Murano
How to put 0 on blaupunkt2030
You use:
- "1" key to enter first digit of code (i.e. if first code digit is 5 you have to push "1" until it shows 5 on your display)
- "2" key to enter second digit of code
- "3" key to enter third digit of code
- "4" key to enter fourth digit of code
- "6" key to confirm code
Aug 02, 2015 | 2001 Peugeot 206 1.6
It keeps asking for a 4-digit code but all the Samsung codes provided are 5 digit codes
if its 5 digit code and it starts with 0 then remove the 0 . failing that post what you are using the code for what unit is it ??
Mar 30, 2015 | RCA Televison & Video
I need the formatting code
Try these default security codes:
Default 4 Digit user code: 1234 or 0000
Default 5 Digit Security code: 12345 or 00000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Jan 05, 2011 | Nokia 6111 Cellular Phone
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
Goldstar tv code for magnavox remote
Depending on the age of your magnavox remote, it may require a 3 digit or 4 digit code. Check the manual of your magnavox remote and see if it requires 3 or 4 digit codes. Once you know what type of codes the remote requires, use the 3 or 4 digit code banks below. Start with the first code in each listing and continue down the list until you find one that works.
Here is a listing of 3 digit codes for GoldStar TVs:
GOLDSTAR: 002 - 102 - 117 - 207 - 217 - 307 - 502 - 818 - 914
Here is a listing of 4 digit codes for Goldstar TVs:
GOLDSTAR: 0019 - 0030 - 0032 - 0056 - 0178
Aug 06, 2009 | Televison & Video
Remote codes for k2598u tv
Seeing that you haven't listed 'all' the codes that you have already used i decided to add these. Didn't know if it was 3 or 4 digit codes you needed so i posted them all. If there are codes in the 3 digit list that aren't in the 4 digit list just add a zero before the beginning and try them (that's if your using the four digit codes!)
eg. 3 digit code not on the 4 digit code list is 053 > then try 0053.
All the best,
Hughie. (codes below.)
4 digit.
0053
0011
0016
0047
0066
0103
0412
0413
0029
3 Digit codes
011,
016,
047,
053,
066,
157,
158,
176,
412,
413
Jun 19, 2009 | Konka K2568U 25" TV
URC-4060B06 Need 3 digit code
Go to the One for all website. Look for the codes for the URC-4080. It will list a 4 digit code, drop the first digit and you now have a 3 digit code. It worked for me so give it a try.
Mar 03, 2009 | One For All Televison & Video
Samsung SCH-a870 Cellular Phone Logo
23 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
