Question about Coby MID8065-8 - Kyros MID8065 8 8 GB Tablet - Wi-Fi - ARM
Coby mid8065 my coby mid8065 stock i restart my coby mid8065 but i stock on android logo how to restart a hard reset my coby mid8065 pls help me.
    New Friend:
  • 21 Answers
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
Posted on Jun 03, 2014
6ya staff
SOURCE:
Coby mid8065 zero internal memory
Seems like your memory is full. Try to remove some apps or data or move them to your SD card. If not contact Coby.
Nov 14, 2014 | Tablets & eReaders
Why my coby mid8065 stop working i try the reset button but still nothing happen, it show the coby logo and the android but didn't go far.
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Sep 08, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
I need help i have a pattern password for my coby tablet mid8042 can you please help me reset it so that i cAn get into it and not have the pass word any more
Press and hold the power on off button while holding vol key up for about 10 seconds untill android logo shows up then release buttons that should take u to the recovey menu once ur there scroll down to factory settings or data wipe select it with onboff button once ur done select reboot system now that should fix ur problem
Aug 06, 2014 | Coby Electronics Corporation Coby Kyros...
How can i fix this, i cant even turn on my tablet koby 8065, every time i open it, it just stopped with the koby logo
It's stuck you should take it to where you have a warranty so they can fix the button that's stuck
Jul 10, 2014 | Coby MID8065-8 8 Inch Android 4.0 Tablet
Hang
Turn OFF the device
2. Make sure its turned OFF
3. Press and hold simultaneously POWER + BACK + HOME buttons
Apr 16, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
How to root
hmm you need to delete some things 1st or add more memory ...
Mar 29, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
I have a coby kyros mid8065 It was stuck in the android logo Technicians said that firmware is broken Do you have any Or do you know what to do
he is right
only solution is to go for factory reset or firmware upgrade
can go to authorised ervice centre too
Mar 05, 2014 | Tablets & eReaders
Coby MID8065-8 - Kyros MID8065 8 8 GB Tablet - Wi-Fi - ARM Logo
392 people viewed this question
Top Coby Tablets & eReaders Experts
 Mike M
Mike M
Marvin
Marvin
Lawrence Oravetz
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
