Hi there. I've renewed a SHARP ar 5012 copier, refilled toner, refilled developer, changed drum unit, everything worked fine, but I've got an error message, the toner/developer lamp blinking, and I tried the C exposure C exposure 24 Start 06 Start method, no success...
Whats the problem?
I have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Well first off if you changed the drum Unit you should reset the counter for that as well. And before you do a developer reference make sure your white reference measurement is cleaned that's the white strip underneath the glass. , Are you aware that you are suppose to enter sub-codes. If you need help and r in the Ct area contact us.
http://www.copierspluswwllc.com
U have to do a developer setting white referance setting and reset counters
Replace the toner cartridge and reset the developer with command 42 sub 01.
how do I refill the developer for Sharp AR5618
