Are the cubes normal - the right size, not hollow? Once frozen and the harvest cycle begins, does it take longer than a couple minutes for the cubes to drop? After the ice drops does it fill with water each time?
If everything checks OK the last thing is very important. The rate at which an ice maker produces cubes depends on the temperature of the freezer - the colder it is the quicker the cycle. Try nudging the controls up a bit and wait 24 hours.
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
The problem is one of two places,
the ice maker is the reason or the dual water control valve=> 4389177
Try pouring tap water inside the ice maker if cubes are not there. Let freeze
and if ice drops into the ice bucket then the water control valve on the side
that feeds ice maker is bad. GS5SVAXVA00 Parts
List Look up in the scrollbar and go to page 17 and you will see the water
control valve listed an item 5 and item 15 is the ice maker thermostat. That or
the ice maker module are most times at fault if the water control valve for ice
maker side had 120vac connected to it water would possibly flow. I have found
that sometime if the ice maker is bad just to replace would be the best route,
Tell me how the water test goes and if someone has a multi meter or ohm meter I
will answer how to test those components, Thanks, Sea Breeze
Click
here=> 2198597
Ice Maker Assembly
