I was cleaning my keurig. put the water reserve full of vinegar. nothing is plugged yet when I close the lid it only lights the large cup and when I press it brews for awhile then about an inch of water comes out sometimes nothing
SOURCE: Not Brewing
We have had this problem intermittently but we had a bigger problem that I solved yesterday. Our LCD display was not displaying properly - words were missing so we just had to guess when it was ready to brew. I called Keurig and they offered a new one for $100 since it was out of warranty. They did ask me if I had descaled the machine and, I'm embarassed to say, I had never done that. Well I descaled the machine and viola! - my LCD display completely came back just like new! Here's hoping the intermittent brewing problem is resolved as well! If you haven't descaled the machine recently, I would strongly suggest giving that a try for any problems you might be having. Of course, to descale, the machine has to at least be able to brew in order to get the vinegar through the machine...
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
SOURCE: My Keurig just started only filling my mug 1/2
Have you tried following the descaling procedure given in your owner's manual? The mineral build-up from hard water can cause low flow, and since the machine pumps for a fixed time this means less water in the cup. Descaling usually brings back normal operation.
SOURCE: The Keurig is heating up the water, yet is does
1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker.
SOURCE: Our platinum keurig has stopped
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Cleaning & descaling your Keurig brewer is an important step to enjoying the best tasting coffee and keeping your brewer in good shape for years.
4 Comments
How often you need to do it depends heavily on how often you use your brewer and how "hard" your local water is ("hard" meaning how many minerals are in it). I try to do this 3-4 times a year.
Comment
Recommended For You
Open the top of your brewer and remove the K-cup holder. CAUTION: There's are two sharp needles in there. Be careful.
Comment
The cup holder is dishwasher safe. You can toss it in the dishwasher if you want. Otherwise a good rinse under warm running water is usually good. There's a sharp needle in here, so be careful.
Comment
5
Turn the cup holder over and ensure these holes at the bottom are free of any obstruction.
Comment
6
The drip-tray is removable. Give it a good clean either by hand or in the dishwasher.
Comment
7
The upper portion of the K-cup holder also has a needle. This needle has three holes in it. Insert a straightened paper clip into each hole to remove any buildup or obstructions.
1 Comment
8
Here's a close up: There's nothing you can break in here, so use some force and get that paperclip a good inch in and wiggle it around vigorously. Repeat this for the two other holes in the needle.
1 Comment
9
Use a damp, soft cloth to wipe away any coffee grinds or water stains in and around the cup holder area, and down the front of the brewer.
Comment
10
Be careful of that needle inside when wiping it down.
Comment
11
Put the K-cup holder back in the chamber. Make sure it's the right way around by aligning the arrows at the top of the holder.
Comment
12
Empty the water in the brewer's external reservoir.
2 Comments
13
Refill the reservoir with undulated white vinegar and replace on your brewer.
1 Comment
14
Run four large cup brew cycles. DO NOT use a K-cup, just run it empty . Dispose of the hot vinegar after each. This pushes the vinegar through the inside heating tank as well as all the valves inside.
2 Comments
15
Leave your brewer to stand, powered on for four hours. This allows the vinegar time to break down any build up in the tubes and valves inside the brewer.
1 Comment
16
Discard any leftover vinegar then refill the reservoir with water only.
Comment
17
Run large cup cycles until "Add Water" is displayed on your brewer's screen. This washes out all traces of vinegar from the insides of the system.
Comment
18
If you notice a vinegar-like smell or taste to the water coming out of your brewer, refill the reservoir with water a second time and run hot water cycles until empty.
3 Comments
19
Congratulations!! Your Keurig brewer is now clean and your ready to enjoy full cups of delicious coffee for months to come!
3 Comments
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
