Restart your laptop.
After it shows acer logo..Press F8 multiple times... (preferably 3 to 5 times)
a screen will show you multiple options.. Select Safe mode (this will be first option and then hit enter... It will show you your Window name (windows 7 / windows xp) press enter again and it will boot your window in safe mode
regards,
Bilal
SOURCE: Acer aspire one not booting
your laptop has been turned off without shutting down. all your laptops registries are probably messed up. the easiest way to do is to reformat your computer or restore it to factory settings. unless you have some important files that you cant afford to lose.
SOURCE: forgot password for acer aspire 5315 laptop
Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use Password Tools from it.
SOURCE: Acer notebook keeps repeating startup process, and wont load.
some time it is due to corrupted system files, and other is take it t service if it is older
SOURCE: doesn;t boot even in safe mode
From the info you supplied, it appears to be the hard drive. You mention safe mode. Are you getting a menu to go to safe mode?
SOURCE: acer aspire one stuck on windows safe mode restart
If you have the option of going to a command prompt (on the choose how to start "text" screen), do it, and type at the C:> fdisk /mbr then press the ENTER key. This may fix things. Also, try removing the battery when the computer is off, wait about a minute, then replace it and start computer. This actually helps sometimes.
